Перенос проекта из Linux на Openwrt
Сообщение letatis » 31 мар 2015, 19:41
Помогите пожалуста уже какой день мучаюсь немогу вкурить :ps_ih:
есть програма написанная на си
 *   Copyright (C) 2004 by Nicolas Sutre                                   *
 *   nicolas.sutre@free.fr                                                 *
 *   Copyright (C) 2005 by Bob Dempsey                                     *
 *   bdempsey_64@msn.com                                                   *
 *   Copyright (C) 2005 by Julien Etelain and Edward Nys                   *
 *   Converted to C                                                        *
 *   Commented and improved by Julien Etelain <julien.etelain@utbm.fr>     *
 *                             Edward Nys <edward.ny@utbm.fr>              *
 *   This program is free software; you can redistribute it and/or modify  *
 *   it under the terms of the GNU General Public License as published by  *
 *   the Free Software Foundation; either version 2 of the License, or     *
 *   (at your option) any later version.                                   *
 *   This program is distributed in the hope that it will be useful,       *
 *   but WITHOUT ANY WARRANTY; without even the implied warranty of        *
 *   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the         *
 *   GNU General Public License for more details.                          *
 *   You should have received a copy of the GNU General Public License     *
 *   along with this program; if not, write to the                         *
 *   Free Software Foundation, Inc.,                                       *
 *   59 Temple Place - Suite 330, Boston, MA  02111-1307, USA.             *
#ifdef HAVE_CONFIG_H
#include <config.h>
#endif
#include <string.h>
#include <stdio.h>
#include <usb.h>
#include <assert.h>
#include <sys/time.h>
#define STR_BUFF 256
#define false 0
#define true 1
#define CMD_INIT      0x00
#define CMD_SETDBT1      0x01
#define CMD_SETDBT2      0x02
#define CMD_RESETCNT1   0x03
#define CMD_RESETCNT2   0x04
#define CMD_SETOUTPUT   0x05
usb_dev_handle *locate_xsv(void);
int ia1 = 0;
int ia2 = 0;
int id8 = 0;
int ipid = 1;
int numread = 1;
int debug = 0;
int dbt1 = -1; // (-1 => not to set)
int dbt2 = -1; // (-1 => not to set)
int resetcnt1 = false;
int resetcnt2 = false;
int delay = 0;
static int takeover_device( usb_dev_handle* udev, int interface )
   Only avaible on linux
#if defined(LIBUSB_HAS_GET_DRIVER_NP) && defined(LIBUSB_HAS_DETACH_KERNEL_DRIVER_NP)
   char driver_name[STR_BUFF];
      Clear buffer
   memset( driver_name, 0, STR_BUFF );
      Ensure that the handle is not null, else program exists
   assert( udev != NULL );
       Read driver name, if found display it
   if ( usb_get_driver_np( udev, interface, driver_name, sizeof(driver_name) ) < 0 )
      if ( debug )
         fprintf( stderr, "get driver name: %s\n", usb_strerror());
      Disconnect eventual driver yet connected to device.
   if ( 0 > usb_detach_kernel_driver_np( udev, interface ) ) {
      if ( debug )
         fprintf( stderr, "Disconnect OS driver: %s\n", usb_strerror());
   } else
      if ( debug )
         fprintf( stderr, "Disconnected OS driver: %s\n", usb_strerror());
#else
#endif
      Set device configuration (conforming to vellman protocol)
    usb_set_configuration(udev, 1);
      Try to get exclusive rights on the device
   if( usb_claim_interface(udev, interface) <0 ) {
      fprintf( stderr,"%s\n", usb_strerror());
      return false;
   } else if ( debug )
      fprintf( stderr,"Find interface %s\n", interface);
   if ( debug )
      fprintf( stderr, "Took over the device\n");
   return true;
   Search the XSV device, and open it
   Return the handle on sucess
         else return NULL
   struct usb_bus *bus;
   struct usb_device *dev;
   usb_dev_handle *device_handle = 0;
   usb_find_busses();
   usb_find_devices();
    for (bus = usb_busses; bus; bus = bus->next) {
      for (dev = bus->devices; dev; dev = dev->next) {
         if ( (dev->descriptor.idVendor == 0x10cf) &&
              (dev->descriptor.idProduct == ipid ) ) {
            device_handle = usb_open(dev);
            if ( debug )
               fprintf(stderr,"XSV Device Found @ Address %s Vendor 0x0%x Product ID 0x0%x\n", dev->filename, dev->descriptor.idVendor,dev->descriptor.idProduct);
            return device_handle;
   return NULL;
   Convert a string on n chars to an integer
   Return  1 on sucess
         0 on failure (non number)
int Convert_StringToInt(char *text, int *i)
   return sscanf(text, "%d", i);
   Write help to standard output
void display_help ( char *params[] ) {
   printf("K8055 version 0.3 UTBM Build\n");
   printf("Copyright (C) 2004 by Nicolas Sutre\n");
   printf("Copyright (C) 2005 by Bob Dempsey\n");
   printf("Copyright (C) 2005 by Julien Etelain and Edward Nys\n");
   printf("\n");
   printf("Syntax : %s [-P:(number)] [-D:(value)] [-A1:(value)] [-A2:(value)] [-NUM:(number) [-DELAY:(number)]]\n",params[0]);
   printf(" [-DBT1:(value)] [-BDT2:(value)] [-reset1] [-reset2] [-debug]\n");
   printf("   -P:(number)      Set board number\n");
   printf("   -D:(value)      Set digital output value (8 bits in decimal)\n");
   printf("   -A1:(value)      Set analog output 1 value (0-255)\n");
   printf("   -A2:(value)      Set analog output 2 value (0-255)\n");
   printf("   -NUM:(number)   Set number of measures\n");
   printf("   -DELAY:(number) Set delay between two measures (in msec)\n");
   printf("   -DBT1:(value)   Set debounce time for counter 1 (in msec)\n");
   printf("   -DBT2:(value)   Set debounce time for counter 2 (in msec)\n");
   printf("   -reset1         Reset counter 1\n");
   printf("   -reset2         Reset counter 2\n");
   printf("   -debug         Activate debug mode\n");
   printf("Exemple : %s -P:1 -D:147 -A1:25 -A2:203\n",params[0]);
   printf("\n");
   printf("Output : (timestamp);(digital);(analog 1);(analog 2);(counter 1);(counter 2)\n");
   printf("Note : timestamp is the number of msec when data is read since program start\n");
   printf("Example : 499;16;128;230;9;8\n");
   printf("499 : Measure done 499 msec after program start\n");
   printf("16  : Digital input value is 10000 (I5=1, all other are 0)\n");
   printf("128 : Analog 1 input value is 128\n");
   printf("230 : Analog 2 input value is 230\n");
   printf("9   : Counter 1 value is 9\n");
   printf("8   : Counter 2 value is 8\n");
   Read arguments, and store values
   Return true if arguments are valid
      else return false
int read_param(int argc,char *params[])
   int erreurParam = false;
   int i;
   ipid = 1;
   for (i=1; i<argc;i++)
      if ( !strncmp(params[i],"-P:",3) &&
           !Convert_StringToInt(params[i]+3,&ipid) ) erreurParam = true;
         if ( !strncmp(params[i],"-A1:",4)  &&
             !Convert_StringToInt(params[i]+4,&ia1) ) erreurParam = true;
         if ( !strncmp(params[i],"-A2:",4) &&
             !Convert_StringToInt(params[i]+4,&ia2) ) erreurParam = true;
         if ( !strncmp(params[i],"-D:",3) &&
             !Convert_StringToInt(params[i]+3,&id8) ) erreurParam = true;
         if ( !strncmp(params[i],"-NUM:",5) &&
             !Convert_StringToInt(params[i]+5,&numread) ) erreurParam = true;
         if ( !strncmp(params[i],"-DELAY:",7) &&
             !Convert_StringToInt(params[i]+7,&delay) ) erreurParam = true;
         if ( !strncmp(params[i],"-DBT1:",6) &&
             !Convert_StringToInt(params[i]+6,&dbt1) ) erreurParam = true;
         if ( !strncmp(params[i],"-DBT2:",6) &&
             !Convert_StringToInt(params[i]+6,&dbt2) ) erreurParam = true;
         if ( !strcmp(params[i],"-debug") ) debug = true;
         if ( !strcmp(params[i],"-reset1") ) resetcnt1 = true;
         if ( !strcmp(params[i],"-reset2") ) resetcnt2 = true;
         if ( !strcmp(params[i],"--help") || !strcmp(params[i],"-h") ) {
            display_help(params);
            return false;
      Send parameters to standard error
   if ( debug )
      fprintf(stderr,"Parameters : Card=%d Analog1=%03d Analog2=%03d Digital=%03d\n",ipid,ia1,ia2,id8);
   switch (ipid) // Board address
      case 1 : ipid = 0x5500; break;
      case 2 : ipid = 0x5501; break;
      case 3 : ipid = 0x5502; break;
      case 4 : ipid = 0x5503; break;
      default : erreurParam = true;
   if (erreurParam)
      printf("Invalid or incomplete options\n");
      return false;
   return true;
   Function to send a command without parameters
   command=CMD_INIT   Initlialise device
   command=CMD_RESETCNT1   Set to 0 the counter 1
   command=CMD_RESETCNT2   Set to 0 the counter 2
int write_empty_command ( struct usb_dev_handle *xsv_handle, unsigned char command ) {
   unsigned char data[8];
   memset(   data,0,8);
   data[0] = command;
   if ( debug )
      fprintf(stderr,"write_empty_command(0x%x,0x%x);\n",xsv_handle,command);
   if ( 0 > usb_interrupt_write(xsv_handle,0x1,data,8,20) )
      return false;
   return true;
   Function to send DebounceTime commands (CMD_SETDBT1,CMD_SETDBT2)
   command=CMD_SETDBT1 used to set debounce time for counter 1
   command=CMD_SETDBT2 used to set debounce time for counter 1
   ATTENTION : t1 and t2 values are not msec !
      use msec_to_dbt_code
int write_dbt_command ( struct usb_dev_handle *xsv_handle, unsigned char command, unsigned char t1, unsigned char t2 ) {
   memset(   data,0,8);
   data[0] = command;
   data[6] = t1;
   data[7] = t2;
   if ( debug )
      fprintf(stderr,"write_dbt_command(0x%x,0x%x,%d,%d);\n",xsv_handle,command,t1,t2);
      return false;
   return true;
   Write output values
int write_output ( struct usb_dev_handle *xsv_handle, unsigned char a1, unsigned char a2, unsigned char d ) {
   memset(   data,0,8);
   data[0] = CMD_SETOUTPUT;
   data[1] = d;
   data[2] = a1;
   data[3] = a2;
   if ( debug )
      fprintf(stderr,"write_dbt_command(0x%x,%d,%d,0x%x);\n",xsv_handle,a1,a2,d);
      return false;
   return true;
   Read input values
int read_input ( struct usb_dev_handle *xsv_handle, unsigned char *a1, unsigned char *a2, unsigned char *d, unsigned short *c1, unsigned short *c2 ) {
   if ( 0 > usb_interrupt_read(xsv_handle,0x81,data,8,20) )
      return false;
   if ( a1 )
      *a1 = data[2];
   if ( a2 )
      *a2 = data[3];
   if ( d ) {
      *d = ((data[0 ]& 0x10) >> 4) | ((data[0] & 0x20) >> 4) | ((data[0] & 0x1) << 2) |
          ((data[0 ]& 0x40) >> 3) | ((data[0] & 0x80) >> 3);
   if ( c1 )
      *c1 = data[4] | data[5]<<8;
   if ( c2 )
      *c2 = data[6] | data[7]<<8;
   Function to convert msec to the DebounceTime encoding
   ATTENTION : Empirical values
int msec_to_dbt_code ( int msec ) {
   if (msec < 2)
      return 1;
   else if (msec < 10)
      return 3;
   else if (msec < 1000)
      return 8;
   else if (msec < 5000)
      return 88;
      return 255;
   Set bounce time of counter number 1
int set_counter1_bouncetime ( struct usb_dev_handle *xsv_handle, int msec ) {
   return write_dbt_command (xsv_handle, CMD_SETDBT1, msec_to_dbt_code(msec), 0 );
   Set bounce time of counter number 2
int set_counter2_bouncetime ( struct usb_dev_handle *xsv_handle, int msec ) {
   return write_dbt_command (xsv_handle, CMD_SETDBT2, 0, msec_to_dbt_code(msec));
   Set to 0 counter 1
int reset_counter1 ( struct usb_dev_handle *xsv_handle ) {
   return write_empty_command(xsv_handle,CMD_RESETCNT1);
   Set to 0 counter 2
int reset_counter2 ( struct usb_dev_handle *xsv_handle ) {
   return write_empty_command(xsv_handle,CMD_RESETCNT2);
   Give current timestamp in miliseconds
inline unsigned long int time_msec ( void ) {
   struct timeval t; struct timezone tz;
   gettimeofday (&t,&tz);
   return (1000*t.tv_sec)+(t.tv_usec/1000);
int main (int argc,char *params[])
   int i;
   char c;
   struct usb_dev_handle *xsv_handle;
   unsigned char a1, a2, d;
   unsigned short c1, c2;
   unsigned long int start,mstart=0,lastcall=0;
   start = time_msec();
      Load parameters
      If parameters are valid continue
   if (read_param(argc,params))
         Initialise USB system
         and enable debug mode
      usb_init();
      if ( debug )
         usb_set_debug(2);
         Search for the device
      if ( !(xsv_handle = locate_xsv()) ) {
         printf("Could not find the XSV device\nPlease ensure that the device is correctly connected.\n");
         return (-1);
      } else if ( !takeover_device(xsv_handle, 0 ) )   {
         usb_close(xsv_handle);
         return (-1);
      } else {
         write_empty_command(xsv_handle,CMD_INIT);
         if ( resetcnt1 )
            reset_counter1(xsv_handle);
         if ( resetcnt2 )
            reset_counter2(xsv_handle);
         if ( dbt1 != -1 )
            set_counter1_bouncetime(xsv_handle,dbt1);
         if ( dbt2 != -1 )
            set_counter2_bouncetime(xsv_handle,dbt2);
         mstart = time_msec(); // Measure start
         for (i=0; i<numread; i++) {
            if ( delay ) {
               // Wait until next measure
               while ( time_msec()-mstart < i*delay );
            read_input ( xsv_handle,&a1, &a2, &d, &c1, &c2 );
            lastcall = time_msec();
            printf("%d;%d;%d;%d;%d;%d\n", (int)(lastcall-start),d, a1,a2,c1,c2 );
         write_output(xsv_handle, ia1,ia2,id8);
Который прекрастно рабоет после установки libusb.
Как эту программу перекомпилировать для openwrt ar71xx??
для компиляции простенькой программы использовал http://robocraft.ru/blog/electronics/1053.html все работает но проблема в том что в нем нет библиотеки libusb как её туда можно поставить или надо пересобирать весь тулчеин или мб ещё чтото?
letatis
programming: ruby
Re: Перенос проекта из Linux на Openwrt
Сообщение noonv » 01 апр 2015, 10:42
а кросскомпилятор библиотеку видит?
